Old 24-Aug-2011, 9:53 PM   #7
MisterMe
Originally Posted by Gebo View Post
Looking to get the top 7 on my list. At this point, I only want and inside antenna.
You are fairly close to the transmission towers for the broadcasts that you want. Your problem is the terrain. The signals are blocked by mountains. As close as you are to the transmission towers, you should be able to pick-up just about anything that you can get with a fairly modest antenna--if it is located in the right place and pointed in the right direction. Three other words--elevation, elevation, elevation! Your best reception may not be adjoining your residence. Walk around your property with a decent, but modest, antenna attached to the end of a long pole. See what you can get outside the shade of trees and what not. You might find that your reception varies dramatically at different locations in the back yard.
