Thread: Help for 98282
Old 24-Aug-2011, 7:18 PM   #8
DBLOCK
That looks like the correct setup. Here's what's on the back of the box:
PM61112
Pre-Amplifier Unit:
Bandwidth 40-860 MHz
Gain V:28 dB, U:22 dB
Max Output Level 105 dB Micro V
Input/ output Impedance 75/300 ohms
Noise Fig. 4 dB/below AT500MHz
Amplifier Unit:
Input Voltage AC120V
Output Voltage AC24V
Input/Output Impedance 75/300 ohms
I put the antenna back up on the roof and rotated it a little to the east. I picked up a couple channels, lost a couple. I'll play with the mount location, and maybe height if I can't get channel 5 (I think if I get this one, then everything else should be available), then set up a rotator also included in the free stuff.
Thanks for all your help so far! Much appreciated...
DBLOCK is offline   Reply With Quote
