Old 24-Aug-2011, 6:03 PM   #17
JeremeyN
can i use my DB8 and combine it with a High VHF Antenna. Or do I have to get a seprate antenna that only does UHF? You also mentioned a Combination antenna 7-69. How would I get that station that's 25 degrees to the north. Do I divide the two location... I assume this works well with LOS but 1-2 edge... It would be sweet If that worked out great.
I'll research some more with those amps you mentioned.
Jer
Select *EITHER* a combo 7-69 antenna *OR* a combination of two antennas, one for high-VHF 7-13 and a separate UHF antenna combined with the UVSJ.
Beyond the PA18, you might look into one of the ultra-low noise amps from RC or Kitz. While I haven't done any testing of either of them and I'm not recommending them, their published specs would indicate the potential of up to a 1.5 to 2 dB dB improvement in the system noise figure.
JeremeyN is offline   Reply With Quote
