Old 24-Aug-2011, 3:06 PM   #21
Originally Posted by John Candle View Post
Ok , for the coax wiring. The U4000 antenna and preamp will have coax that goes to a location where there is power for the preamp and the coax can be split with a 2 way splitter , one output of the 2 way splitter goes to one Tv and the other output of the 2way splitter goes to the other Tv. . The coax of the second antenna the HD7694P antenna will go to the same location and a 2 way splitter is connected to the coax of the second antenna and the outputs of the splitter go to the two Tv's. Connect the coaxes to the remote control A/B antenna switches , the locations of the A/B antenna switches is at the Tv's , and the output of switches connect to the Tv's. Now with the remote control in your hand you can change antennas with out leaving your chair.
Neither the U4000 nor the HD7694P has enough gain to pick up a FOX station.
The 91XG has the most gain on channel 45, but even then it will be unreliable.
