Thread: Antenna Help
Old 24-Aug-2011, 9:57 AM   #8
John Candle
Tv Antennas and Reception
As AD Tech has suggested you can go with 2 antennas , a Antennas Direct Clear Stream 5 aimed at about 230 degree magnetic compass for the reception of KXLY 13 ABC and KSPS 7 PBS. The CS5 comes with a UVSJ = UHF-VHF-separator-joiner. And the second is a Antenna Craft U4000 , UHF antenna aimed at 194 degree magnetic compass. The 2 antennas are connected to geather with the UVSJ and the output of the UVSJ is connected to the CPA-19 preamp. This 2 antenna set up will work better then the one antenna.
