Old 24-Aug-2011, 6:58 AM   #15
JeremeyN
K I lowered my Antenna by 10' and readjusted and now I am getting my best results with Channel 2, 6, 22, 28, 34. All the channels, except for 22 - CW (mid 70s), I get a signal strength between 60%-67%. If I got a better Pre-amp would this increase... Or would I be better to get a more directional Antenna. I don't mind having 2 antennas in the end. Even if it means me giving up on the DB8. I figure I can can use a HBU55(pointed towards 129°) and an Antenna Craft Y10-713 (Pointed 105°) and use a combine the two signals with suggested Holland UVSJ. But What would be the best Amp to get.
To me If I can can get the current channels through through a multi-directional I would think a Directional Antenna would do better with the right amp.
So would my plan potentially work better than I have and what amp is recommended.
Thanks In Advance,
Jer
JeremeyN is offline   Reply With Quote
