Old 24-Aug-2011, 5:37 AM   #16
MisterMe
What about WXIN, real channel 45, the OP's stated goal? Per the OP & http://en.wikipedia.org/wiki/WFXW the local Fox affiliate has or will change it's affiliation to ABC. WXIN is weak, but the only viable option for a FOX affiliate. WCCU is a tropospheric path... not viable at all.
I thought my point was very clear in my post. If you click through on the WXIN link, then you will see that Terre Haute sits in a hole in WXIN's coverage. This is the say that the TV Fool model shows that the OP should receive nothing from WXIN. Although the WCCU signal is weak in Terre Haute, it is not zero (0). This is why I recommended that the OP forget WXIN, which he probably cannot get, and go with WCCU, which he has a chance to get.
MisterMe is offline   Reply With Quote
