Ok , for the coax wiring. The U4000 antenna and preamp will have coax that goes to a location where there is power for the preamp and the coax can be split with a 2 way splitter , one output of the 2 way splitter goes to one Tv and the other output of the 2way splitter goes to the other Tv. . The coax of the second antenna the HD7694P antenna will go to the same location and a 2 way splitter is connected to the coax of the second antenna and the outputs of the splitter go to the two Tv's. Connect the coaxes to the remote control A/B antenna switches , the locations of the A/B antenna switches is at the Tv's , and the output of switches connect to the Tv's. Now with the remote control in your hand you can change antennas with out leaving your chair.
