Old 24-Aug-2011, 12:52 AM   #5
richnerd
GroundUrMast, thanks for your response and info. If a DB-8 was chosen would could be expected (loss) if installed in the attic? Is it possible to pick up VHS with this unit?
Ok, so far the mentioned antennas are the Winegard HD7698P and the AD DB-8.
Let me ask a few more questions as I learn more:
Do you recommend a pre-amp no matter what antenna is chosen for my location? If so, is there a best "bang for the buck" pre-amp or will the pre-amp need to match the antenna chosen (as say John recommended-Antennas direct CPA-19)?
Are there any pros/cons to having a solo or dual antenna setup?
How much more could the HD7698P get me for my area? ...I only ask in the sense that I'm not sure I'm reading the TV fool antenna info correctly. i.e. the "C" means duplicate station???
More info: I expect to have three to maybe four tv's hooked up to the OTA. I'm also looking into the best setup to utilize OTA, Netflix, etc. I'm looking into the HDhomerun, Roku and using Windows MP. Any recommendation in this area is also appreciated.
Thanks again.
richnerd is offline   Reply With Quote
