Old 23-Aug-2011, 11:41 PM   #12
Tower Guy
Originally Posted by JeremeyN View Post
So I am a bit confused... Will I get a better signal by having an antenna At Ground Level???
That's unlikely. There will be an optimum height that will defract off the ground in front of your antenna and hit the ridge.
Even then, you may get a better signal off a bounce in an odd direction than direct.
You're headed toward alot of experimentation.
