Old 23-Aug-2011, 10:35 PM   #12
John Candle
Tv Antennas and Reception
Ok , I recommend a 2 antenna set up with a remote control A/B antenna switch , model AB27RS or radio shack 15-1968 , at both Tv's. The first antenna will be a AntennaCraft U4000 with a Antennas Direct CPA-19 preamp. aimed at about 92 degrees magnetic compass for the receptions of WTIU PBS , WTTV The CW , WCLJ Ind. WIPX ION Tv , WRTV ABC , and through the back side of the U4000 , W43BV TBN. . I also recommend a Winegard HD7694P antenna with NO amplifier aimed at 208 degree magnetic compass , for the receptions of , WTOW NBC , WFXW Fox , WTHI CBS. . Here is how to aim Tv antennas , http://www.tvfool.com/antenna/pointing/pointing.html . I will return with coax wiring instructions.
