Reliable reception of CH-45 is going to be challenging. An XG-91 pointing toward 62° and an Antennas Direct CPA-19 are going to give you some signals. You will need to experiment with mounting height. (Anywhere from ground level on up.) You can order an extra director section for the XG-91... that would increase it's gain a bit more.
CH-45 may not be 100% reliable.
Can you afford a tower?
