A high gain antenna for channels 7 thru 13 is Winegard YA 1713 antenna. Use the Antennas Direct CPA-19 preamp. Aim the antenna between 105 degree magnetic compass and 130 degree magnetic compass. Signal strengths at your receive location show the strongest signals at about ground level. You will most likely find a compromise of height and finding a good reception with less or no trees the direction of the transmitters.
