No, analog signals are just that: analog. Your TV tuner also has analog reception built in to it, and you are seeing an unconverted analog signal. A better antenna properly aimed at the transmitter will likely yield better results. Try grabbing a compass and aiming your antenna as close to 138 degrees as you can as measured by your compass to optimize the signal.
