Old 23-Aug-2011, 2:20 AM   #2
Originally Posted by Tide1 View Post
I have a DB8 Antenna in my attic with a Wineguard Pre-Amp (8777 maybe??).
Basically I would like to add a VHF antenna and combine it with my DB8 and also have it to go thru the pre-amp as well if needed.
Add an Antennacraft CS600. http://www.solidsignal.com/pview.asp...na-%28CS600%29
Use a UVSJ to combine the antennas. http://www.solidsignal.com/pview.asp...nna-%28UVSJ%29
You don't need a preamp, and it may reduce your reception.
If the preamp is a 7777 there is a mode switch that allows it to be used as a VHF/UHF combiner, but try the UVSJ first.
