W23BZ at a -12.7 NM (dB) to start with and a reliable signal at the Tv , thats very good. -10 NM(dB) is the number that reception usely drops out. Turning the antenna to the left and right , you might find a spot that the signal strength is a little higher. When reaching out for these low signal strength stations , you get in to moving the antenna around to find a hot spot. You can also do antenna stacking. Two antennas stacked one on top of the other or side by side. You can also go to the >>Start MAPS<< part of tvfool and put in different antenna heights to see if the transmissions get stronger.
