Old 23-Aug-2011, 1:59 AM   #1
Tide1
Need VHF Antenna Help
I have a DB8 Antenna in my attic with a Wineguard Pre-Amp (8777 maybe??).
I thought I could do without a VHF antenna but now I realize I am missing out on 2 local stations (WVTM-13) and (WUOA-23). I checked out dtv.gov and it says that WVTM is a HI-VHF and WUOA is a LO-VHF. I have been looking at antennas and the majority of VHF seem to be geared towards the HI-VHF. I am only 16 miles or so as the crow flys from the towers which are in the same direction. Also, I ocassionally have reception of WVTM but it cuts out, and the other I really can't get a signal with the DB8.
Basically I would like to add a VHF antenna and combine it with my DB8 and also have it to go thru the pre-amp as well if needed. I need help on the type of combiner or splitter I should use and how to connect the two.
My tvfool link is below:
http://www.tvfool.com/?option=com_wr...9e74cfa35b50f1
Thanks in Advance.
Tide1 is offline   Reply With Quote
