Rerun your TVFool prediction using the "start MAPS" option, if you haven't already done so. Enter as much of your address as you want, then use the Google map that displays on the next page to accurately locate the receive point (drag the pointer to right over you - zooming in will be necessary). You can quickly measure the possible impact of additional antenna height by entering different values in the box and letting the predictions refresh each time.
I'm curious about the neighbor's claim. I'm behind the times as far as what repeaters are still active - is he getting the old analog translators from Moorefield (the channels listed in purple at the top of your TVFool report) or is he getting the direct digital broadcasts from Harrisonburg and other places? Specifics will help gauge what might be possible for you.
