Thread: Help for 98282
Old 22-Aug-2011, 6:27 PM   #5
If it was as easy as snapping our fingers, mounting at 60' AGL obviously offers far better signal conditions than close to the ground.
It sounds like you have already figured out that unneeded splitters are a liability. You're on the right track... Get the antenna safely up at 30' AGL then prove it good into one set with no splitters.
I have not been able to find information regarding the PM6112. Is the system a two part design, an outdoor unit and power insertion devise for indoor installation? If so, I think you may have cited the part number from the power module.
