Moving the antenna up to 25' AGL would significantly improve the signal strength. Currently, WFWA-PBS, real channel 40 arrives at a predicted NM of 17.9 dB. At 25' AGL that improves to 25.3 dB. An improvement of 7 and a half dB is worth the effort.
I would make mounting at 25' the number one priority.
You are on the edge regarding an amplifier. If money is tight, I would understand taking this one step at a time. Personally, I'd spring for a CPA-19 and be done with that part of the project.
I would hold off spending money on a new antenna, the added elevation will buy much more, I would replace the antenna as a last resort.
