Thread: Help for 98282
Old 22-Aug-2011, 4:23 PM   #4
DBLOCK
Antenna: Philips MANT901
Preamp/amp: Philips/Magnavox PM6112
I brought the antenna down to ground level thinking it was my location, but found I had just too many splitters! I found at least 4 on the line I was trying to test the system on...
I disconnected from my distribution box and went straight to the TV and have 8 stations: 13-1 13-2, 12-1, 12-2, and 4 around channel 20. this is with the antenna on the ground and pretty much pointing towards earth.
I want to hook up 3 tv's & maybe have a connection for FM.
I'll put the antenna back up on the roof (at least 30ft up) to see if I now get reception, but have been considering mounting the antenna in a tree too. I have plenty of straight, tall trees to choose from. A couple are already topped for me too. The tree option will result in a lot more RG6 in the system though.
Here's the rooftop (30ft AGL) data: http://www.tvfool.com/?option=com_wr...9e742bc01a6960
Here's the treetop (60ft AGL) data: http://www.tvfool.com/?option=com_wr...9e7477b2c570da
Last edited by DBLOCK; 22-Aug-2011 at 5:23 PM. Reason: Add rooftop & treetop mount TVFM
DBLOCK is offline   Reply With Quote
