If your goal is to receive as many stations as possible, you need to choose a high gain antenna, it's that simple. Mounting high, and free of buildings, trees and other obstructions will almost always pay in greater signal strength and quality.
A combination UHF/high-VHF antenna that fits the criteria of high gain is the Winegard HD7698P. It's high-VHF performance (real channels channels 7 through 13) beats the performance of the best consumer grade cut-to-band antennas by about 2 dB. It's UHF performance is about 2 dB less than the best consumer grade UHF-only antennas. (Antennas Direct XG-91 and Winegard HD9095P)
Because KETA-PBS, real channel 13, is so weak, I would be uncomfortable suggesting an antenna with less high-VHF gain than the HD7698P. KOCO-ABC is also quite weak and would need a high performance antenna to be seen.
A good low-noise preamp such as the Antennas Direct CPA-19 would be needed.
Your answer to John's questions will determine whether a rotator or a multiple antenna installation is better for you. In homes with two or more TV's, rotators will be a source of conflict when the antenna needs to point in more than one direction at the same time.
