It would also help if you could post a TVFool report based on the actual height above ground level for the actual antenna installation. Your first TVFR is based on a default of 10' AGL. Do you have Douglas Fir or other straight, tall trees on your property, and would you consider mounting an antenna on the tree? If so, how high?
