Old 21-Aug-2011, 5:07 AM   #6
Same antenna and hook up situation as the other house. Separate coax from the antennas to the location of the Tv and a remote control A/B switch. Aim the U8000 antenna at about 245 degree magnetic compass. A advantage of the U8000 is the reflector bars of the antenna can be turned so they are more in line with bar they are mounted on , this turns them out of the way so the V shaped metal reception elements will receive more signal at the back side of the antenna.
