Originally Posted by whiskeyhill
I e-mailed one of their people, and I was told that their transmitter is in Schaumburg, IL. Therefore, it is the one at 352 degree magnetic compass.
The fellow recommended the following equipment:
Channel Master 4228HD - 15.6 db average gain
Radio Shack Antenna Amplifier Model:15-259 with 33 db average gain
Based on the predicted signal levels, that or JC's suggestion of the U8000 will be plenty of antenna.
I don't think you will need any amplifier though. (Save the money.) In fact I would expect the RS amp listed, to overload and cause trouble. I'd prove the need first, then I would be careful to use an amp with high input capability.
