Old 20-Aug-2011, 9:52 PM   #7
John Candle
Tv Antennas and Reception
Well Ok then. I recommend a AntennaCraft U8000 with no preamplifier. Aim the antenna at 352 magnetic compass. You will need to run a separate coax from the antenna to the Tv and connect a Remote control A/B antenna switch to the two antennas at the location of the Tv. A/B antenna switch AB27RS or radioshack 15-1968. The U8000 will also receive WYIN-DT 17 PBS through the back side of the U8000 antenna.
