Thread: Newbie advice
Old 20-Aug-2011, 7:14 PM   #19
jakkwb
There is no water or moisture in the coax connection to the antenna (is that the transformer?). I just had the antenna supplied boot on (over) it. It does not seem like it seals very well. Should I put some sealer around it?
Also, the coax I am using was from a previous dish network installation. The cable appears to be in good shape, however, the installer spliced it in one place. It has screw on connectors, however, there is no water proofing at all on this splice except for the rubber gaskets on the coax around where the connectors are attached. The actual connection between the two cables is not sealed.
Thanks again, John.
jakkwb is offline   Reply With Quote
