Thread: Best Antenna?
Old 19-Aug-2011, 3:11 PM   #8
pduggs
Originally Posted by John Candle View Post
Go to the neighbors and see if . WXSP MyNetwork , WTLJ Religion , WXMI FOX - Antenna Tv - This Tv , WGVU PBS , are being received , they are the strong channels that might overload the amplifier in the MS2000. If these channels are being received then you should be Ok also. I say give the MS2000 a try. Please note that omnidirectional antennas are not really 100 % omnidirectional and my need to turn the antenna for best reception and then tighten the clamps. If you receive Tv stations down to W17DF-D 17 you will be doing fine. The stations that are below W17DF have co channel interference and adjacent channel interference so even with a better antenna you will still have reception problems with some of the co channel / adjacent channel interference channels. . Buy googling the stations call letters like this , w17df tv , I found that w17df tv is FOX - Antenna Tv - This Tv . w48cl tv is 3ANB 3 Angles Broadcasting Network , wuhq tv is ABC - The Cool Tv .
Thank you both.
I am only interested in getting the stations on the list down to W17DF-D. I think I will buy the MS2000 and see how well it works. If it overloads the strong stations I will return it.
Do you guys have any suggestions on where I should buy it?
pduggs is offline   Reply With Quote
