Old 19-Aug-2011, 2:38 PM   #13
lukepoll
Thanks a lot, guys...you have been very helpful!
Bummer...the garage door is made of sheet metal, so the indoor antenna solution is probably compromised, although it may deserve a shot anyway. If you discourage even a first try in the closet, I will probably consider the Techshield-free sport in the attic with a monodirectional, non-amplified antenna. Which one do you think is the best around?
Do you know the return policy of Amazon, in case the antenna that I choose does not work at all?
Thanks!
lukepoll is offline   Reply With Quote
