Thread: Very New to OTA
Old 19-Aug-2011, 5:54 AM   #2
John Candle
Tv Antennas and Reception
A fairly good choice , Put it up and lets see what channels are received. Aim the antenna at about 253 degree magnetic compass , Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html . WKBT-DT 8 CBS is at a angle to the antenna but should be received Ok because it is a strong signal. WIBU-LP 51 ION Tv and Family Net , is to the back of the antenna and may not be received. Install the antenna and see what can be received and not received. I recommend new RG-6U coax from the antenna to the connection at the house. Connect to only one Tv for now , No Splitters , every time the signal is split the signal strength is reduced.
