If you are going to cut existing cable in a satellite installation, expect to find 'quad-shielding', two foil layers combined with two braided layers of shielding. The connectors will need to be selected based on the cable. Fortunately, the big box home improvement centers usually carry the connectors and tools.
If the existing dish is active, you can usually insert an OTA/Satellite diplexer. One port accepts the signal from the dish, the other input port accepts the signal from the OTA antenna. If the dish is not active, don't worry about it, let the next person put a connector and 'F' barrel in to restore the satellite connection, presuming they want it.
