The root of the cause is the , distance , and the strength of the signal , the height of the receiving antenna and the Sun Shine , during the day time the sun shine blasts away and knocks the signal out. And during the day time the changing layers of the atmosphere warp the signal , moving the signal up and down and all around. Also at night the weak signal is warped by the atmosphere. The way to over come these situations if it can be , is , more antenna height , a bigger better antenna that you already have in the 91XG , moving the antenna around to find a hot spot where the signal is stronger and you can also use a Antennas Direct CPA-19 preamplifier.
