Old 18-Aug-2011, 6:54 PM   #2
Tower Guy
Originally Posted by H3Tank View Post
If I am looking at Multiple antenna's do these numbers matter in making a decision? If so, what should I be looking at.
You should be looking at the TV channel assignments in your area, the angles to those transmitters, and the available signal level at your house.
The antenna that you linked to is a quality high-performance antenna. It's a good choice if you have low band VHF, high band VHF, and UHF all in the same direction with NM values in TVfool of 30 db or less. There are very few cities where all these are true.
