Old 18-Aug-2011, 4:33 PM   #3
Rich
Thanks Dave. I will let you know how the Mohu goes when the DTA box arrives.
I like the garage attic location as it is easier to work in.
As I thought more about this whole situation, I realized that I grew up with cable television. I have never run antenna wires through a house. How do people run wires through walls to where their TV is located? In particular, the upstairs TV is located in the corner of two outside walls, which I am sure are full of insulation. Also, from the attic the wire would have to go thorugh the upstairs walls, the footers for the wall, down into the downstairs wall. I have worked home constrution in the past so I unsderstand how walls are constructed. I just don't see an easy way to snake wires through to all locations. Any thoughts or advice anybody?
Finally, while I have some understanding of electronics (from playing with it as a kid) I don't really get why different antennas work differently. There seem to be so many models. Can anybody point me to some primer on antenna design/function/theory?
Cheers,
Rich
Rich is offline   Reply With Quote
