Tv Antennas and Reception
Ok here is your situation. A Winegard HD7082P antenna on a Channel Master CM9521A rotor and -- - - - No antenna preamplifier- - - - will get you the Tv stations from Chicago and Milwaukee. Connected to one Tv this Ok , the person that has the remote control of the rotor has control of where the antenna is pointed. However having a antenna and rotor connected with more then one Tv will lead to conflict of the direction of the antenna. Here is another way to do it for two Tv's , 2 antennas and 2 rotors on 2 separate antenna mounts with coax from one antenna going to one Tv and coax from the other antenna going to the other Tv , the 2fers is pricey but it will allow each person to watch what they want on there own Tv.
