Old 18-Aug-2011, 4:02 AM   #7
No static at all
No static at all's Avatar
The absolute minimum antenna I would use would be the Winegard 7694, but if you can move up to the 7696 or higher, that would be even better.
You need something that has the ability to reject multipath, which is best addressed by a more conventional / directional antenna. I'm assuming ghosting was a problem with analog reception which would indicate excessive multipath.
