Old 18-Aug-2011, 12:41 AM   #16
Ryan Van
Originally Posted by John Candle View Post
I suggest point the CM4228 at 177 degree magnetic compass to the south and point the ANT751 at 104 degree magnetic compass to the south east. Separate coax from each antenna will go to the location of the Tv and a AB27RS remote control A/B antenna switch or a radio shack 15-1968 remote control A/B antenna switch will switch between the antennas. Mounting on the roof top will help.
I returned the ANT751 so I could afford the CM4228. The antenna is currently mounted on the lower of two roof tops (it's mounted on the garage roof), my rental company will not allow me to drill in the roof at any locations. I currently modified the DirecTV mount to accommodate the CM4228.
Ryan Van is offline   Reply With Quote
