Old 17-Aug-2011, 8:42 PM   #4
I am recommending the HD769X series because it tends not to receive much signal from the rear. In your case there are several stations using the same channel, so there is a possibility for 'co-channel' interference. An antenna with a high 'front-to-back' ratio is able to ignore signals from the rear, which is what you need to reduce the possibility of interference from stations using the same frequency.
Because you said,
i really only want the basics - CBS, NBC, ABC etc.
I offered a solution that does that (plus quite a bit extra).
I think you will see several strong signals from the side or rear though.
