I think that you will probably be fine when you are all done: I would have used dedicated TV masting, which is easier to work with, but you'll be OK. When installing the antenna on the rotator, remember that in order for the compass points to line up properly on the rotator that the antenna must be pointed due SOUTH (180 degrees)
