You've described an attic that may be reasonably friendly to a working antenna. If you have a lot of room in the attic, consider the Winegard HD7694P or even the larger variants of the same series. Two factors may work against you. First, the known co-channel interference, and second, the un-known effect of the attic construction. The directivity and good front-to-back ratio of the HD769X antennas will help with the first. Going with an antenna that has higher gain helps with the second.
Aim toward NYC. (250°)
