John,
Thanks for all the information.
I have a small problem with this antenna. I put it together today, it has a manufacturing defect. When you put all three pieces together, the end with the longest elements sticking out is rotated about 10-15 degrees from all the other elements. The longest elements are not on the same plane as all the others. It is slight.... looks like the drilled holes to connect the tubes together are not exactly 90 degrees from the element plane.
Will this be a problem?
You are right. It is as big as a house!
