Old 16-Aug-2011, 6:37 PM   #3
Originally Posted by pizzle85 View Post
When it comes to rotating antennas i'm not exactly sure how they rotate. Am i able to program in angles for different channels and have it automatically rotate depending on the channel? If so is this only necessary for the farther channels?
Would this sort of usage be possible with a single antenna or should i look at getting something for locals and another for the Tampa stations and switching back and forth.
Thanks for the assistance,
-Pizzle
Typically, a rotator is manual. You're often better off with two antenna, one for locals and one for another city. All you'd need is an A/B switch. If your TV set can't add stations during a rescan, you'll need to switch directions while the TV scans. It may take a few scans to figure out the sequence and timing.
You might find the Jacksonville stations easier to pick up than Orlando or Tampa.
