Tv transmissions to the south south east are what will be received in the green and red shaded part. KAIT 8 ABC , KTEJ 20 PBS , KVTJ 48 IND. , are in the green shaded area and will be easy received. WMC-DT 5 NBC and a digital sub channel named (This Tv) , are Very Weak in the red shaded area and will Not be easy received. I recommend a Antennas Direct CPA-19 preamp. Use only the splitter that is needed. If 2 Tv's are connected use a 2 way splitter. If 3 Tv's are connected use a 3 way splitter. I Strongly Recommend Install all new RG-6U coax on the outside and on the inside of the house. WMC is a Very Weak signal so only the best coax signal transference should be used. I also recommend a coax ground block be used and connected to the house electric service ground wire. The reason for the coax ground is , WMC is Very Weak , so need to get the cleanest most interference free signal to the Tv. Using a coax ground block will direct interfering static or electric/electronic interference to ground.
