Old 16-Aug-2011, 12:31 AM   #2
John Candle
Tv Antennas and Reception
As with so many others , here are 2 facts that you need to understand. Having a mind set of hiding antennas is , B , A , and D = BAD. The truth is that antennas need breathing room to receive Tv transmissions. And the number 2 fact is that having a amplified indoor antenna can make the reception worse. The Tv stations/channels at your location are Very Strong and can easy overload a amplifier. Here are Non Amplified indoor antennas , http://forum.tvfool.com/showthread.php?t=233. Aim the indoor antenna at about 235 degree magnetic compass. Here is how to aim indoor Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html . Also read and understand this about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channel , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695 . To receive the digital broadcast Tv channels , the Tv or tuning device will be set to search for the Digital Broadcast Tv Channels , Not cables channels and Not Analog channels.
