Old 15-Aug-2011, 11:18 PM   #14
Here is one of the reasons I suggest the CM 4228HD antenna. These are actual facts of antenna measurements. Using a redesigned CM 4228HD That is redesigned for better reception of VHF high channels 7 thru 13. The closing statement of the Author is , For the author , the choice would be the CM4228HD. Since it fairs very well in the UHF Shoot out , as well as in this VHF Shoot out. It becomes a very clear choice. http://www.antennahacks.com/Comparis...F_Shootout.htm . I know it is technical , thats why I present it , It proves a point. I present this information because you said you will like to have a smaller antenna. Will the CM4228HD do the job?? I say yes. However if it does not , ask Fry's if you can return the CM4228HD and get the HD7697P. You ask , so now you have some information and you can choose the road.
