Old 15-Aug-2011, 4:59 PM   #9
John Candle
Tv Antennas and Reception
The stations in the green shaded area of the tvfool radar report are strong and can be received with a indoor antenna. But first I need to know about the home construction. If the home is wood frame with wood or vinyl siding , Tv signals pass easy through wood frame and wood or vinyl siding. Tv signals pass easy through flat composition roof shingles. Tv signals pass easy through insulation that is Not foil backed. If however the house has metal siding , a metal roof , concrete walls , brick from ground to roof , foil backed insulation , the Tv signals will be reduced or blocked. What is the construction of your house??
