Old 31-Mar-2010, 11:47 PM   #2
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
You shouldn't have any difficulty receiving the KC stations cleanly where you are. All of the stations operate on UHF, and are less than 30 miles from your location. I would recommend roof-mounting a screen-type UHF antenna aimed at 150 degrees as measured by your compass. Good antenna choices include the Channel master 4221 HD, the Winegard HD-4400 and the AntennasDirect DB-4.
If you have only one TV set, and your cable run from antenna to TV is less than 75', I don't believe that you'll need a preamplifier, but if you plan to run multiple TV sets or have very long cable runs, consider a Winegard HDP-269 preamp and a splitter, which will allow you to run up to 4 TV sets from the antenna without signal loss. Here is a list of the recommended equipment and an installation guide.
http://winegard.com/kbase/upload/HD-4400.pdf
http://channelmaster.com/product-ove...D=136&catID=33
http://winegard.com/kbase/upload/WC-809%20_HDP-269.pdf
http://www.solidsignal.com/pview.asp...u=853748001040
http://manuals.solidsignal.com/AntInstallGuide.pdf
