Ok I ended up buying the Winegard HD-8800, 100 ft new cable and compression connectors (all new). I chimney mounted and pointed towards the antennas that will give me the few remaining channels I wanted to get.
I currently get the following channels
12-1 WXLI
12-2 This-TV (WXLI)
20-1 WCWG
20-2 WCWG-D2
20-3 WCWG-D3
20-4 WCWG-D4
26-1 UNC-TV
26-2 UNC-KO
26-3 UNC-EX
45-1 WXLV-HD
45-2 WXLV-SD
48-1 WMYV-HD
48-2 WMYV-SD
Now the channel I am wanting to get is WFMY & WGHP which I don't get to come in. whats weird is that tower and the tower for WYMV are so close, within miles and very tight on the map I still cant get WFMY.
I have moved the antenna around a lot and I finally got the WFMY 2-1 and 2-2 to come up but no picture. In other words I can tune to the channel but no picture.
Is the next step an amplifier and if so which do you recommend for the HD-8800 I purchased.
