Tv Antennas and Reception
I recommend 2 Channel Master CM4228HD antennas , 1 aimed at 127 degree magnetic compass and the 2nd aimed at 329 degrees magnetic compass. both antennas will have a Antennas Direct CPA-19 preamp. Separate coax down leads will go from each antenna / preamp to the area where the Tv is at and be connected to a remote control A/B antenna switch. Model # AB27RS or radio shack Model # 15-1968. Using the hand held remote control you can select either antenna with out leaving your chair. The CM 4228HD antenna is a very directional antenna that will lessen the multipath reception , and the CM4228HD also receives the VHF high channels in addition to the UHF channels. I know you say you will only like to receive 4 channels , however the other channels will be received because they are of the same directions. So may as well watch them also.
