Old 13-Aug-2011, 6:08 PM   #1
willpower2
multipath/multidirectional conundrum
Folks, Same as most others-which antenna(s) is/are best for my rather dismal situation (zip 93420) which is as follows: tv fool link -- http://www.tvfool.com/?option=com_wrapp ... 28a67582fc -I am only interested in 4 channels--Ch. 15, NM +41, distance 16.5 miles and ch. 34, NM +23 same distance both at 329 degrees mag. both single multipath. At 112 degrees mag. --ch. 19, NM +5, distance 26 mi.-- and at 127 deg. mag. -ch. 27, NM +6 distance a mere 54 miles, both double multipath. I plan to roof mount with a Titan 7777 pre-amp feeding one Panasonic hdtv through 50 ft. of RG-6. I would prefer 2 antennas with the right sort of combiner instead of a rotator. (Unless one miracle antenna could do this job). I can get maybe 10 ft. of horizontal separation and a bit of vertical. There is some slight treetop interference at 329 deg. (stronger signal) but clear at 112/127. With these differences in signal strength, direction, and multipath issues, I am at a loss. Any advice would be wonderful. BTW, I e-mailed for advice to Solid Signal with details of my situation, and the tech recommended a multi-directional with built in pre-amp, Winegard MS 2000. I have serious doubts. http://www.tvfool.com/?option=com_wr...3e47f5e849994a
Last edited by willpower2; 13-Aug-2011 at 6:19 PM. Reason: tvfool readout incomplete
willpower2 is offline   Reply With Quote
